Reply
Nighthawk 5G Mobile Hotspot Pro
chazzyb
Follower
How can we extend the signal on the
we already have an orbi 50, are they compatiable?  Can we bypass the wifi on the nighthawk 5g hotspot or is there a better answer?
we are attempting to cover about 2300 sq ft of office and 20,000 sq ft of warehouse
thanks
Message 1 of 2
JBish
Re: Nighthawk 5G Mobile Hotspot Pro
I would suggest getting the antennas for it to broaden range... Believe it uses 2 x TS-9 which mount on back of unit... Under the 2 plugs you see on each corner of device...
Message 2 of 2
Discussion stats
  • 1 reply
  • 289 views
  • 0 kudos
  • 2 in conversation
Announcements
