× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk MR1100 IPv6 on LAN
csw219
Follower
I’ve gathered from older posts that, although the Nighthawk M1 supports IPv6 on the WAN side and that you can receive an IPv6 address while connected to it, it does not support IPv6 on the LAN and blocks ICMPv6. This is means that a router attached to the M1 will not be able to provide IPv6 to devices attached to it.
My question is, are there any plans to upgrade the firmware of the M1 to support IPv6 on LAN, and is there anyway to currently get the M1 to provide IPv6 to a router attached to it?
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 2
Blanca_O
NETGEAR Moderator
Re: Nighthawk MR1100 IPv6 on LAN
Hi @csw219
Welcome to NETGEAR Community!
Nighthawk M1 mobile router supports IPv6 on LTE/WWAN side. The option has to be configured when configuring APN. On the LAN side, IPv6 is not supported as there is no options to configure it.
We recommend posting your suggestion on our Idea Exchange board. Our Product Managers review the board for great ideas to be implemented in future releases. Link is https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Blanca
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2539 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
