- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
need to repair MIMO Antenna (6000450) by replacing a TS-9 connector
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a broken TS-9 connector on my MIMO antenna and would like to replace it. But I can't find any technical info on the antenna cabling to ensure I order the correct model.
Here's an example of a supplier with two different types for different cable diameters:
https://www.showmecables.com/catalogsearch/result/?q=TS-9+Connector+
"RM" & "LMR" are two of the codes used to designate cable types and the # indicates the diameter. More info:
https://www.showmecables.com/blog/post/coax-coaxial-cables
It does not appear to be a difficult operation (https://www.youtube.com/watch?v=4ADx01VUUyg) although I may need a coax stripper.
Where can I find technical info on my antenna that indicates the cabling type so I can get the correct TS-9 connector? Alternatively, does Netgear sell parts? They should because these TS-9 connectors are fragile.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: need to repair MIMO Antenna (6000450) by replacing a TS-9 connector
Is this a weird question? I thought it was kinda standard.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is nothing "Netgear" about this sort of problem. The same appraoch will apply to anything that has an antenna that needs fixing.
Have you tried a wider search? YouTube has all sorts of "how to mend it" videos.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry Mike,
but that's not helpful. I actually put a link to just the sort of resource you mentioned in my original post. And I think I was quite clear that I need to know the cabling Netgear uses on the antenna so that I purchase the correct type of TS-9 connector - they vary in size to accommodate the various sizes of coax cabling.
