edjenn1998's avatar
edjenn1998
Armor Will not activate
Armor will Not activate. I gave up on phone support after waiting for too long to get a person to help. I used the chat support and I was told to basically unplug the router for 2 min and restart it and to re-install the app. Still the exact same thing. Everytime I try to activate the armor protection I get a message stating that it timed out and failed to activate and try again. I have a RAX45 / AX4300 Nighthawk Router. IS there anything that can be done to fix this?
  • plemans's avatar
    try turning remote management off and then back on or vice versa
    • edjenn1998's avatar
      edjenn1998
      did not work. It was off so I turned it on and then back off. No good. I trying it on. no good.
