StLFan
Aug 24, 2022Guide
Bitdefender blocking malicious host on iPads
Hello,
I have an Orbi RBR40 with 3 satellites. Netgear Armor with bit defender/VPN installed on iPads. In the last 2 weeks, I’ve started getting warnings that ‘malicious host blocked on iPad’ for some suspicious websites (that I have never accessed). It does not tell me the source for these attacks. I’ve cleared cache and website data, frequently, and even removed email accounts (aside from iCloud). The attacks seemed to stop for two days but started up again, with a different website blocked this time.
How can I tell what is the source and finally put a stop to this? I don’t surf the internet, only go to reputable sites or use apps. Nothing is jailbroken.
Any help would be appreciated.
Thanks
If you're getting the reports daily, shut off your devices and only use 1. Watch for the notices. That'll help you narrow it to a specific device.
From there you can work on seeing if something on it is causing it. It could be something on a site you go to or even an app that does have something nefarious in it. Tough to know with the info you've given.
- StLFanGuideI’ve done that. It seems it happens when either iPad is asleep and plugged in, usually within 10-25 mins. Infrequently, I get a message that ‘Page was blocked. The page you were trying to access was dangerous and was blocked for your protection.’ This is while the iPad was asleep and plugged in early this morning.
You can go into armor and see what sites are being blocked.
https://kb.netgear.com/000061032/NETGEAR-Armor-is-blocking-URLs-that-I-want-to-access-what-do-I-do
It also has more info on why it was blocked.
It could be an app in the background updating its connection and that being an issue
