KiwiChris
Jan 08, 2022Aspirant
How do I remove a router from Armor?
I have two routers under Netgear Armor and need to remove the nighthawk one as it no longer exists. I have searched without success as to how to do this and cannot contact Netgear support as my products have both lapsed. Can anyone help?
- nielsvdsLuminary
You can find how to do this here : https://kb.netgear.com/000060900/How-do-I-turn-NETGEAR-Armor-on-or-off-using-the-Nighthawk-or-Orbi-app
A factory reset of the router and setup from scratch will also disable Armor.
