Orbi WiFi 7 RBE973
Reply
Netgear Armor by Bitdefender Subscription
SandSBW
Follower
Several weeks ago I signed up for the free trial version of Netgear Armor for my RBR50 Orbi router.  Several days ago, I received an email from Netgear Armor offering at 35% discount on a subscription.  I bit the bullet and signed up, received an activation code, but have not yet submitted it (activated the subscription).  I have 67 days left on my free trial.  If I activate the subscription with the activation code, will that add on to the end of my free trial period, or will the activation end the free trial and begin the subscription?  If it ends my free trial, can I wait until the free trial period ends to activate the subscription (which I've alread purchased)?  None of this is explained anywhere.
Message 1 of 7
Re: Netgear Armor by Bitdefender Subscription
Armor has its own bolt hole:
NETGEAR Armor - NETGEAR Communities
You might do better to try there.
Message 2 of 7
DexterJB
NETGEAR Moderator
Hi @SandSBW, activating it will end your trial but the activation code does not expire so you can use it at the end of your trial.
Message 3 of 7
Orbi-Roc
Luminary
Hi @DexterJB . Just to make sure I understand this, an activation code is issued by Bitdefender upon purchasing Armor for USD 79/year. Based on your response to @SandSBW , the clock doesn't start ticking on the one-year paid Armor subscription UNTIL IT IS ACTIVATED, not from from the purchase transaction date. So if I buy the Armor Netgear license today May 10th but only activate it on June 30th, my one year subcription will start from June 30th. Is that correct?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 4 of 7
DexterJB
NETGEAR Moderator
Hi @Orbi-Roc, yes, you are correct.
Message 5 of 7
garyalbert
@DexterJB - You are mistaken.  The PR says the new subscription starts after the trial period but from experince it starts the day you make the purchase.  I thought the same but I subscribed with 3 weeks left on the trial (figured it would kick in afterwards) but the clock started ticking the day I made the purchase.
Message 6 of 7
DexterJB
NETGEAR Moderator
Hi @garyalbert, welcome to the community. If by any chance you have proactively activated your code, then that will end your trial as I have also mentioned in one of the posts above. This link provides the description.
Dexter
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 15272 views
  • 2 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
