Joselp's avatar
Joselp
Tutor
Feb 24, 2024
Netgear Armor subscription not working
I wanted to activate the netgear armor in my router rax120 (I have got 3 netgear routers registered and in different locations)
The nighthawk app did not give me the possibility to activate (Plan not available). I was asked to call to get it fixed.
While talking to support:
1-Logged in armor.netgear found out that only 2 routers appeared and 1 one them was showing the router r7800 while the serial number was the one of the rax120 (strange)
2-Support said they would activate it for the rax120 and I would be able to then subscribe from the app, that worked so from the app I could see the option to active, and I did via the app (up to the payment), then received and email to activate the subscription via web, I picked the router with the right serial number, however when I clicked on details and devices the router which got the activation is not the rax120 but the r7800. So the activation has been done to the wrong router. And btw in the app of the rax120 again is saying plan not available.....
I called again but waiting for ages with no response
3-In my netgear I can see the routers with the right serial numbers, all correc
  • Update:
    Armor site for the rax120:1- shows the right router image and serial number; 2-In subscriptions shows as active; 3-shows no devices connected
    Armor site shows r8000 with devices connected and on line while the nighthawk app does not show it at all (anywhere access is enable for all); r7800 is not showing in armor
    Nighthawk app: Shows armor expired, if I clicks gives the option to suscribe with a 70% discount; FYI there are around 50 devices connected
    BTW the Nighthawk app has never worked too well meaning the devices I have are not showing properly: For the RAX120 most of the times anywhere access is not visible and not working; R7800 shows off line when is not; and the r8000 dows not show at all. I access to rax120 from home
    I confirm armor for rax120 is not working
    It has been with Netgear support for a while now without solution
