brise's avatar
brise
RBR50 High Risk Vulnerability
Netgear Armor (free trial) has completed a vulnerability assessment on my network and has identified a High Risk vulnerability on the RBR50 router itself. The description is "Basic auth found". Can someone explain that to me and what I should to do fix this?  Basic auth on what? - orbilogin.com??
Thanks.
  • Yes, a vulvenrability on the router itself. See his link:
    Netgear products vulnerable to authentication bhpass flaws
    I think this is what the scan result you got means. I thought for sure that this had long ago been addressed. Now I understand why Netgear is in no real hurry to roll-out the vulnerability assessment scan functionality! Is this all the scan report says - are there any dates shown or any kind of explanation ...
    • brise's avatar
      brise
      Thanks for the response. I looked at the links you provided and I don't see that the RBR50 was involved. In any case:
      1 - I had already set the password recovery option (as recommended) on the router.
      2 - It turns out that the Armor vulnerability alert showing is on each of the 2 RBS50 *satellites* (not the router). The date shown is yesterday - May 12. No other information is shown on the alert.
      3 - I am able to log in to the router and satellites individually using my admin user/pwd. I didn't expect to be able to log into a satellite - but there are no configuration options there anyway.
      Is this alert something I need to worry about? I guess the satellite access login is available only if already on my network.
      • Orbi-Roc's avatar
        Orbi-Roc
        Luminary
        Hi again brise . I know the Orbi routers weren't part of this Netgear Security Alert. I was merely trying to point out that the issue reported in your vulnerability assessment scan is a known issue to Netgear with other routers; and since their own Netgear Armor reported it in the context of a vulnerability scan, then I assume that the Orbi routes also suffer from the same security flaw. I am no expert at this brise , far from it. I basically have the same Orbi set up you have and it makes me nervous that vulneraribility assessment scans are not being performed on a regular basis; even more so after reading your post.
  • schumaku's avatar
    schumaku
    The description alone as provided is not sufficient - there must be more.
    Basic Auth is a standard way used to challenge usernames and passwords in a Web browser, on http or https sessions, here is what the Web browser shows:
    Especially if this code does pop-up in a http page, it's typically considered a major risk - because of the content (realm, username, password) are going over the network without reasonable encryption.
    Well this is what happens when so-called security systems are thrown on the wide public - completely unrelated "itt's this" are coming back.
    • Eg2020's avatar
      Eg2020
      Tutor
      I'm getting the same vulnerability message for the RBR50 router. I also get one for my Ecobee thermostat. Unfortunately there is no other detail provided in the report.
      • schumaku's avatar
        schumaku
        As I wrote above:
        "Basic Auth is a standard way used to challenge usernames and passwords in a Web browser, on http or https sessions, ... if this code does pop-up in a http page, it's typically considered a major risk - because of the content (realm, username, password) are going over the network without reasonable encryption."
        Except for the "special case" where the device is the first in the data path (e.g. a wireless extender with mywifiext.net , or a router with myrouterlogin.net , or an Orbi router with orbilogin.net where the device can capture the DNS request and return the LAN IP here is hardly a way to have "clean" https certificate installations on a LAN - without local DNS, without your own domain, ... so it's disputable what is the better choice - non-protected credentials on what should be considered a secure LAN, or even more nasty browser complaints about invalid certificate, ....
  • Just wondering if you use (Tesla) solar panels. On my network this shows up but it is the little wireless adapter that connects the panel inverters to report electric generation. I plan to contact them this week but I doubt I will get a response.
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi all, this has been reported to engineering and is being worked on.
      Dexter
  • Getting the same message, see the file I imported. My software is up to date. Is Netgear doing anything to resolve this threat?
