mgdurand1's avatar
mgdurand1
Luminary
May 06, 2019
Using just Armor with Norton installed
Hi again.  I asked this quesiton this weekend and the answer really did not answer the quesiton I posed.  The topic was immediately closed so I could not post this there.  My question was as follows:
"Just did the upgrade on my Orbi router and satellites to 2.3.0.32.  Gives me the offer to try Armor for 90 days.  Did a very little bit of reading and it appears to be a Bitdefender software system that inlcudes antivirus proteciton.  I know you are not really supposed to run 2 antivirus pprograms at the same time.  Is the same true for this solution?  I run an antivirus as well as a couple of anti-malware programs.  Curious to see if anyone has seen anything on this.  Thanks"
I know I can install the Bitdefender AV and then I should not run 2 antivirus programs.  But the question is can I NOT install the Bitdefender AV software and keep my Norton while running Armor?
Thanks again.
  • Hi mgdurand1 . I raised a similar question a few days ago and never got a response either. Although I was not dealing with Norton AV bur rather Defender on WIN 10 desktop and laptop; and ClamXAV on two MacBook Pros. I don't have Armor installed yet on my router, as I am still debating and reading on it. I have yet to find a good, reliable, review on Netgear Armor and hands-on test and performance assessment.
    The fact the a Netgear moderator did not chime in to answer my question is probably the main reason I didn't jumb on the band wagon and activated the trial.
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi mgdurand1, I believe I've responded to one of your first post and sorry if I was not able to make it clear. As I've also informed Orbi-Roc, yes, you can run Armor alongside your already installed AV's since Armor is doing the check on the router side.
      Dexter
      • mgdurand1's avatar
        mgdurand1
        Luminary
        Thanks.  I was unclear as to the repsonse.  Likely my fault and I apologize.  Happy that I can pay for Armor and not install Bitdefender software.  Sure that is great AV software, but my set (Norton and Malwarebytes) has kept us safe for so long I am hesitant to change it.  Thanks again!
