Orbi WiFi 7 RBE973
Reply
how to activate armor in RS500?
Spendor
Guide
just bought RS500 and set up as AP, with IOS app, there is no Security option on app which all articles saying that it’s the way to activate Armor. i tried this app on iphone 16 pro max and ipad pro, but both has no “Security” option.
Message 1 of 6
Accepted Solutions
Guru
Re: how to activate armor in RS500?
If you set up in AP mode, then Armor won't work. Armor requires router mode for it to work.
Message 2 of 6
All Replies
Guru
Message 2 of 6
Spendor
Guide
thanks a lot, btw, when using RS500 as AP, can i use RBS760 — Orbi Tri-Band Mesh WiFi 6 Add-on Satellite as wifi extender for wifi 6 and 5G/2.4G?
Message 3 of 6
Guru
Message 4 of 6
Spendor
Guide
thanks, what wifi 7 extender or wifi 6 extender from netgear could be compatible with RS500?
Message 5 of 6
Guru
I don't think NG has a W7 extender available yet.
I've use a EAX80 with my RS600 for extended WiFi coverage. Just doesn't support 6Ghz or BE mode is all. You'll get the 2.4 and 5Ghz and all modes up to AX thru it though.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 924 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
