Orbi WiFi 7 RBE973
Reply
BR200 Communicate between two LANs
XSO
Initiate
Initiate
Hello,
I use a BR200 router I don't want to connect to the Internet (and I don't have access).
I want to connect two networks. LAN1: 193.210.10.0/24 and LAN2: 192.168.10.0/24
I want the BR200 to be used to create routes between these two networks.
I was thinking of connecting LAN 1 to port 1 of the BR200. And the LAN2 on port 2 of the BR200. Purpose: To PING a PC that is on LAN 1 (193.210.10.90) using a PC that is on LAN 2 (192.168.10.10). How should I go about establishing this link?
Thank you in advance
Cordially
XSO
Message 1 of 2
Accepted Solutions
JeraldM
NETGEAR Employee Retired
Re: BR200 Communicate between two LANs
@XSO,
Welcome to the community!
In this case, you would need to configure Inter-VLAN routing which you may refer in this document.
JeraldM
NETGEAR Community Team
Message 2 of 2
All Replies
JeraldM
@XSO,
JeraldM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1816 views
  • 1 kudo
  • 2 in conversation
Announcements
