Tacotown's avatar
Tacotown
Parental controls doesn’t do anything
I previously received help for this issue. I wiped ajd reset my router which fixed for some time. I spent a ridiculous amount of time troubleshooting back-and-forth with Netgear support. I am paying for the service and I cannot turn off Internet for any devices. None of the hourly constraints work. I would like to know if there is a fix for this as it looks like this has been going on for many years. I don’t understand why this product is being sold when its most basic functionality is not working for so many people. This seems . I don’t understand why this product is being sold when it’s most basic functionality is not working for so many people. Has anyone found any solutions to the smart parental controls not working properly other than reset your router and set it back up as new. I’ve done that and it works but only for a month or so.
  • FURRYe38's avatar
    What NG router system model do you have?
    What firmware version is loaded on it?
    What mobile device are you using?
    Has a factory reset and setup from scratch been performed since last FW update? If this hasn't been done yet, it will need to be to check this.
    What do you mean by the controls do nothing? Doesn't give much information on what the problem is.
    • DCP4971's avatar
      DCP4971
      Luminary
      I've been happily using SPC for ages (had to do a factory reset to get it working), but I noticed last night that my son was still online long after his time should have been up and when I checked, none of my devices will pause when asked to. I've tried a whole range of different devices to make sure it's not limited to certain kit.
      I'm not sure how long this has been the case - my son may have had freedom for months, I'm not sure.. I've just set it up and left it to it.
      Running V7.2.6.31_5.0.24 on an RBK853 and knowing the issues some have had with .31, wondering if anyone has reported SPC issues with this release that you know of?
      I have a spare day tomorrow, so am somewhat resigned to another factory reset and potentially downgrade to .21, but curious if there is any knowledge of SPC in this scenario.
      Have also logged an Incident with NG support, but not had much help from them previously.
      Thanks.
      • DCP4971's avatar
        DCP4971
        Luminary
        Factory reset done, remaining on .31, SPC now working again. What a PITA..
        Interestingly, when I restored the config file from backup, SPC didn't work, but a fresh reset/re-config (which has given me RSI from re-defining all my reserved addresses) it's working.
        Now to wager how long it will remain working for and will have to set reminders to check in on it periodically.
