okipol
May 31, 2021Aspirant
1Gigabit capable Netgear NAS + Access Point
Hello,
I am a proud owner of Netgear WNR3500Lv2. I have custom tomato running on it (yes deprecated unfortunately).
I have an ISP rated 300 Mbit but on directly conected it could go up to 700 Mbit. I am searching for a router that will be running in AP mode and having NAS 3TB or more. That I want to run on the local network at a Gbit speed (cable of course). I read there are some issues when running in AP mode of achieveing this speed.
I want to run AP + NAS and have Gigabit speed on cable (currently I had issues with the hardware support on my Netgear because of QOS I think). I preordered a
Netgear R6400 Router Wifi AC1750 USB 3.0
Is this suitable or will I have a problem? Thank you in advance.
FYI, you didn't post this in the right forum. ReadyNAS is Netgear's NAS product line - which doesn't include their routers that support USB drives (sometimes called a "NAS" feature).
Netgear routers do drop some features when running in AP mode. It is possible that attached USB drives might be one of them - not sure, since it's not a mode I use. One workaround is to double-route - which works ok, though port forwarding, etc becomes a bit more complicated. Anyway, you might want to follow up in the router forum area.
okipol wrote:
I want to run AP + NAS and have Gigabit speed on cable. I preordered a Netgear R6400 Router Wifi AC1750 USB 3.0You won't get gigabit file transfer speeds (~100 MB/s) using the R6400 NAS feature. Based on this review, it will be around 20-30 MB/s: https://www.pcworld.com/article/2960533/netgear-r6400-review-netgear-s-latest-mid-range-router-is-a-solid-value.html
The R6400 is an older mid-range model, you would get faster WiFi speeds with something higher end. That would be more expensive of course. No idea on whether you'd also get faster NAS speeds.
- okipolAspirant
Hi,
Yeah rewised I am not using AP mode (oh yeah).
Having that in mind I am getting Internet speeds @ Down 400 Mbit / Up 900 Mbit. The NAS is around 20 MB/s. That is a really nice upgrade from my last Netgear WNR3500v2. Also I pay for a symetrics 300Mbit :P. I will be thinking about using some custom Firmware for it ;). I really liked the advanced tomato.
- JAMES1977Aspirant
Hey!
If you are searching for a router that will be running in AP mode and having NAS 3TB or more I advise you to take a closer look
at 4g signal boosters. https://www.myamplifiers.com/en-au/ - more information here. I use them to improve coverage in my home.
