Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
LMS for OS6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-10
07:54 AM
2013-05-10
07:54 AM
LMS for OS6
A LMS (Logitech Media Server) add-on for OS6 would be great.
I am thinking about upgrading to the new OS but need LMS (even if its obsolete).
Anyone got it running from source?
Message 1 of 59
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-24
03:21 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-06
09:49 PM
2013-06-06
09:49 PM
Re: LMS for OS6
will be in my dropbox in a few minutes enjoy and thanks to Govnah
Message 3 of 59
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-07
10:02 AM
2013-06-07
10:02 AM
Re: LMS for OS6
That sounds great super-poussin, how do we get it?
I don't have an OS6 machine yet, but this is the only reason I'm not getting one.
Message 4 of 59
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-07
10:14 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-07
10:18 AM
2013-06-07
10:18 AM
Re: LMS for OS6
vandermerwe wrote: https://www.dropbox.com/sh/ie9pwk1wut72ias/-puRHmcmD2/Logitech%20Media%20server
Oh I see.
How is it installed?
See the readme in the directory. You can install via frontview from the apps tab and see the upload icon top right. Or if you are comfortable with SSH and Linux you can do it from the CLI.
Message 6 of 59
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-08
08:05 AM
2013-06-08
08:05 AM
Re: LMS for OS6
Thanks. I'll consider the purchase now.
How would plugins work with this version, as normal?
Message 7 of 59
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-11
08:59 PM
2013-06-11
08:59 PM
LMS for OS6
Govnah - is the lms deb file a custom build? If so, what did you modify? Maybe we can handle this in a simpler way, so users don't depend on you providing builds.
Message 8 of 59
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-11
09:24 PM
2013-06-11
09:24 PM
Re: LMS for OS6
the lms deb file is the interface for frontview so after installing lms and the logitec deb , you can upgrade the logitech deb without need to insall lms deb file again
Ps : done by me 😛
Ps : done by me 😛
Message 9 of 59
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-11
09:52 PM
2013-06-11
09:52 PM
Re: LMS for OS6
Nice - thanks!
What LMS versions are supported by your add-in?
Message 10 of 59
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-11
10:01 PM
2013-06-11
10:01 PM
LMS for OS6
The one in the Dropbox and upper and perhaps lower version . It will work if Logitech did not rename their startup script
Message 11 of 59
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-11
11:47 PM
2013-06-11
11:47 PM
Re: LMS for OS6
super-poussin wrote: The one in the Dropbox and upper and perhaps lower version . It will work if Logitech did not rename their startup script
I'll do my best not to change it ;-). Thanks again!
Message 12 of 59
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-13
12:58 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-16
02:16 AM
2013-06-16
02:16 AM
Re: LMS for OS6
Hello Super-Poussin. Firstly, thank you for your add on. I managed to install it first time on my Netgear 312. Unfortunately it stopped working just when it was about to finish the library scan. I couldnt get it going at all so I decided to unistall and reinstall it. I followed the same procedure but it comes up with a message saying the second file (lms deb file) failed to install. Then when I go to the app page I can see the LMS app and when I click to turn it on it comes up with a a screen saying 'toggling service - this might take a few minutes', I get the timer going around and it just hangs. Would really appreciate any help you can offer.
ps let me know which currency you have so I can make a donation.
Message 14 of 59
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-16
10:09 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-16
02:20 PM
2013-06-16
02:20 PM
Re: LMS for OS6
Thanks super-poussin. Unfortunately still the same problem. 1.0.3 fails to install. Although when I go to apps and see the LMS icon it says installed. I try to turn it on and it just hangs. Could there be a problem with readygear app site because when I go to 'available' in apps it just gives me the timer and doesnt show any apps. When it was working I could see all the available apps.
Message 16 of 59
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-16
02:30 PM
2013-06-16
02:30 PM
Re: LMS for OS6
Can you post the server.log, from /var/log/squeezeboxserver#?
I don't even use the Apps/Available from frontview as it is severely broken and buggy. I would turn off Genie+market place and just use apt-get and dpkg if you are comfortable SSHing into the box.
Message 17 of 59
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-16
02:56 PM
2013-06-16
02:56 PM
Re: LMS for OS6
'I would turn off Genie+market place and just use apt-get and dpkg if you are comfortable SSHing into the box'.................this way beyond my ability! (unfortunately)
UPDATE: Have done a factory reset and can now load and run LMS.
Message 18 of 59
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-18
03:24 AM
2013-06-18
03:24 AM
Re: LMS for OS6
try this :
dpkg -r lms
dpkg --purge lms
dpkg -r logitechmediaserver
dpkg --purge logitechmediaserver
apt-get update
apt-get install lms
dpkg -r lms
dpkg --purge lms
apt-get update
apt-get install lms
Message 19 of 59
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-18
05:04 AM
2013-06-18
05:04 AM
Re: LMS for OS6
super-poussin wrote: try this :
dpkg -r lms
dpkg --purge lms
apt-get update
apt-get install lms
Update: Did a factory reset before I got the above and LMS app now works. Thanks. Euros?
Message 20 of 59
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-18
11:19 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-07-04
11:53 AM
2013-07-04
11:53 AM
Re: LMS for OS6
Hi,
Thanks for creating LMS GUI for ReadyNAS OS 6.
I have problem, I can't play any of my local music files, all players get same error: Can't open file for: [song title]
All files are in Apple Lossless format.
In server side there is no errors in logs.
I have couple of files in mp3 format and those work fine.
I have tested both 7.7.2 and 7.8.0 versions.
Any idea what could be wrong?
Message 22 of 59
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-07-04
11:55 AM
2013-07-04
11:55 AM
Re: LMS for OS6
Whois is the owner of the files ?
And what are the rights ?
Message 23 of 59
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-07-04
12:44 PM
2013-07-04
12:44 PM
Re: LMS for OS6
User rights are ok, everyone has read access to all music files.
All music files has idendical rights, mp3 files work fine but apple lossless don't.
I even tried: su - squeezeboxserver and then tried to access those files and those are accessble.
One odd thing, with version 7.7.2 all three Radio, Duet and Transporter give same error.
But 7.8.0 Radio plays those files, but Duet and Transporter don't.
Message 24 of 59
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-07-04
03:35 PM
2013-07-04
03:35 PM
Re: LMS for OS6
I made test and converted some music files to flac format, those are working fine.
Made Test directory and copied both m4a and flac files to there with identical file rights and owners.
Added Test directory to LMS Media Folder
Rescan changes
Try to play files from that Test media directrory.
Flac files play fine but ma4 don't.
Rescan changes
Message 25 of 59
