× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNas Duo no access through my PC but accesible with other media
panaye
Follower
When I open Raidar I saw my 2 NAS with all green lights and I can localize them but when I explore them they are empty.
The IP adress are not accessible in my explorer.
My NAS are visible through my PS3 or other media server.
I suspect some issue about windows or security software update.
Can you help me?
Message 1 of 2
Guru
Re: ReadyNas Duo no access through my PC but accesible with other media
If you are using Windows 10 (or 11), then go into "turn windows features on or off" and make sure the SMB 1 client is enabled.  Then open file explorer, and enter \\nas-ip-address into the address bar (using the real NAS IP, and also being careful to use the correct slash).
If you are trying to get to the web ui (https://nas-ip-address/admin), then you likely will be seeing an SSL version error - because most browsers have dropped TLS 1.0 and the legacy ReadyNAS firmware doesn't have anything newer.  There is more information on this here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/Workaround-for-ERR-SSL-VERSION-OR-CIPHER...
Message 2 of 2
Discussion stats
  • 1 reply
  • 999 views
  • 0 kudos
  • 2 in conversation
Announcements
