jgg1950's avatar
jgg1950
Apprentice
Aug 21, 2024
Mr70
If I uninstall nighthawk then reinstall it will it pickup all devices again?
  • FURRYe38's avatar
    As long as you use same SSID name and PW for the wifi, yes.
    • jgg1950's avatar
      jgg1950
      Apprentice
      Yes same said, login. Did the uninstall then reinstalled. No problem. The issue I have is the same devices are displayed but show not connected, yet the are case I can use the apps for those devices es i.e S24 Plus, Samsung TV, Lorex door bell. Even after restarting all of those devices?
      Thanks
  • Hello, Nighthawk on android, local connection, display not pickup . Not changing access. The issue is Nighthawk displays some devices offline, yet they are corrected as I can control those devices from their app. Nighthawk app and firmware upto date. Thanks
    • michaelkenward's avatar
      michaelkenward
      There have been far too many reports of Device Manager getting things wrong.
      Not sure that I understand what that is saying. You say you can "control those devices from their app". How can you do that if the devices don't show in Device Manager?
      You mean that each device has its own apps and you can control if from there?
      Can you control them from a web browser and the graphical user interface (GUI) for the MR70?
      Then the usual boilerplate questions to eliminate some of the more common issues that crop up here.
      What firmware version do you have on the MR70?
      A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware with an app or in the browser interface.
      If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that connects this router to the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
      I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
      Just another user with time on their hands.
      • jgg1950's avatar
        jgg1950
        Apprentice
        For instance my Samsung TV is online ,can use any internet apps, YouTube, Google, IE, etc yet nighthawk doesn't display it. Yes can control them with their own apps. V 1.0.3.34
        Arris S33. My network setup is not new installed 8-2023. Nighthawk issue started a week ago, prior to than no issues. Thanks
