lechatnoir27's avatar
lechatnoir27
Follower
Nov 17, 2020
Can I connect another Router to my MR60?
I have the Nighthawk Mesh 6 Wifi Mesh System.  HOwever, I am still finding tons of dead spots in my house.  I was wondering if you can connect another router through a ethernet port on the Mesh 6?  If so, how do I go about it?
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello lechatnoir27,
    We recommend that the MR60 is set into access point mode when connecting it to another router.
    Christian
    • Boltyk's avatar
      Boltyk
      Christian_R why so?
      Setting mesh system as an access points going to transform your mesh into three separate access points, right?
      • schumaku's avatar
        schumaku
        What's the point of adding a [NAT?] router to a network cable in another part of the location? You would use an access point for such a purpose instead, or e.g. another MR60/MS60 system in AP mode.
        What is the difference - leaving alone the MR60 does not longer act as a NAT router connecting to the Internet - in your opinion? All the Mesh capabilities (seamless roaming) as well as the wireless backhaul between the MR60 and the MS60 are retained.
