MrMusAddict
Dec 08, 2021Aspirant
MR60 How to block devices based on a schedule?
I seem to be able to block/allow devices wholly/completely. I also seem to be able to set a global schedule. But I do not appear to be able to schedule access per device. Is there a way to do so?
I'm using an MR60, accessing the router config page on 192.168.1.1.
Might see if this is seen on your MR:
If not, this model may not support this feature...- MrMusAddictAspirant
FURRYe38 Is there a list of devices I can refer to that support this as a feature?
Select the links in that article under "This article applies to:"
