Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Nighthawk AX3000 Mesh from Costco
ParadiseSML
I purchased, from Costco, the Netgear Nighthawk WiFi Mesh (AX3000 or MK73).  The system works well, but I am in need of adding a third satellite to the system.  The only Nighhawk satellites available are the MS60 (AX1800) and MS80 (AX3600).  Which of these satellites is going to work with the MK73?  My assumption is the MS60, but cannot find an answer.
Message 1 of 7
Guru
Re: Nighthawk AX3000 Mesh from Costco
@DarrenM @ChristineT @KevinLiT
this is the first mention of a MK73 system I've seen. Even a google search only turns up this post.
Message 2 of 7
Guru
Do you need more MS?
The system seems new and thus not sure if any other MS models are compatible.
https://www.netgear.com/support/product/mk73s.aspx
Message 3 of 7
Guru
That makes it interesting. The MK70 series is still dual band but has a wider (160hz) 5ghz channel in a 2x2 configuration.
Both the 60 and the 80 series fronthaul is only a 80hz wide and 2x2. But the 80 series has a 3x3 backhaul that's 80hz wide.
That will make compatibility interesting as you can use 60 series satellites with the 80 series router but not the other way around. Wondering if any of the mod's will chime in with compatibility plans for it.
https://kb.netgear.com/000063029/Which-Nighthawk-Mesh-products-are-compatible-with-the-Nighthawk-Tri...
Message 4 of 7
ParadiseSML
This is the system from the Netgear website (https://www.netgear.com/home/wifi/mesh/mk73s/).  Only available at Costco.
Message 5 of 7
ParadiseSML
The two satellites cover the house well.  They also give me coverage at our dock.  The reason a 3rd satellite is needed is to access our cameras on the dock.  The camera system requires a wired connection, which I can get on a satellite.  I've tried a network extender, but to view on your cellphone both cameras and cell have to be on the same network.
Message 6 of 7
Guru
If you connected a extender, the extender should be on the same network if it's in extender mode and not creating a separate network.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 3130 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
