JayHalo's avatar
JayHalo
Follower
Jul 21, 2016
Blinking Green power LED
I have had this WiFi range extender for about a year and suddenly it quit.  It had only a blinking green power LED.  I unplugged it moved it to the router room and could not make it connect.  I left it unplugged 24 hrs and tried again in the router room.  It hooked right up.  Moved it back to its orginal location and now the same thing.  Only getting a blinking Green LED.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello JayHalo
    Try to do a factory reset and re setup the extender also try a different power outlet in the same room.
    DarrenM
