cavedon's avatar
cavedon
Can EX3700 act as DHCP and NAT?
Hi, I am planning to use an EX3700 AC750 WiFi Range Extender for an untrusted wifi network.
Can the EX3700 act as NAT and DHCP? Even when the network being extended is not available?
Thanks,
Ludovico
    • cavedon's avatar
      cavedon
      Thank you Darren,
      What would you recommend instead? EX6100?
      Thanks,
      Ludovico
      • DarrenM's avatar
        DarrenM
        Sr. NETGEAR Moderator
        none of the extenders will handle DHCP you will have to use a router for that.
        DarrenM
