plutus
Dec 03, 2017Follower
Cannot create account after WPS setup
Hi all,
I've installed my new ex3800 following WPS instructions. Everything works fine but how can I create a netgear account and configure more advanced functions?
Apparently the only solution is a full reset but if I can avoid...
- DarrenMSr. NETGEAR Moderator
- plupluAspirant
thanks for answering. No, I cannot enter into mywifiext since I don't have registered a username/password. When configuring the extender using the WPS function, I wasn't asked to create a netgear account (or whatsoever)...
Here is a guide on how to register the product.
https://kb.netgear.com/26904/Registering-a-Product-on-MyNETGEAR
DarrenM
- plupluAspirant
this is the registration procedure for the warranty....will I gain access to the configuration page in this way?
