6815PG
Dec 05, 2018Follower
Daisy-chaining with an AC1200
Greetings all, just purchased an AC1200 and it's working a treat; simple query, it's not quite hitting the far-reaches of my property. The issue is a bedroom that is located over a hanging carport so lots of structural steel and reinforced concrete in the way!
Does anyone know for sure if I can 'daisy-chain' another AC1200 to extend the range?
The second AC1200 would be sited directly above the first one (ground floor) with little/no interfence between the two.
Thanks in advance
1 Reply
The A6210 is a USB wifi adaptor, and not an extender. Please provide the correct extender model number.
It is possible to daisy chain extenders, but there is a loss of throughput. Powerline networking might be a better option for you (in particular the PLW1000). That would connect to your router over your house wiring, and provide wifi for the bedroom.
