BenParker10's avatar
BenParker10
Follower
Nov 10, 2016
EX3700 - Red light on router, yet it's working?
 Hi guys,
Bit of a weird one. Our EX3700 is working fine, but pretty much all the time has a red 'router' light. Is this just a faulty LED or is there something wrong there? I will add that it does occasionally go green, but not very often.
Cheers,
Ben
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Benparker10
    It could be a faulty LED or it could be on the edge of the wifi signal but if you are not having issues with the extender I wouldn't worry about it.
    DarrenM
