Orbi WiFi 7 RBE973
Reply
Ethernet port stopped working
mjortiz66
The wi-fi still works but the ethernet port stopped.  Extender is about a year old.  I reset the extender but that didn't help.
Any ideas?
Model: WN3000RPv2|N300 WIFI Range Extender
Message 1 of 11
Guru
Re: Ethernet port stopped working
Is the ethernet LED lit on either the client device or the extender?
Did you try switching to a different cable?  Sometimes they do fail.
Message 2 of 11
mjortiz66
Yes, I tried 2 other ones.
Message 3 of 11
mjortiz66
Ethernet light is lit on the extender when plugged in.  The device that's plugged into it does not have a light.
Message 4 of 11
Guru
That sounds like the client device ethernet port.
Can you try connecting the extender to a different ethernet device?  Or perhaps connect the client device directly to the router?
Message 5 of 11
mjortiz66
Yes, that works.
Message 6 of 11
Guru
@mjortiz66 wrote:
Yes, that works.
I suggested two checks - which one worked?
Message 7 of 11
mjortiz66
Sorry....plugging directly into the router.  I don't have another device to test the extender at the moment.  I'm working on my laptop now and can't log out.  I'll have to wait until lunch.
Message 8 of 11
mjortiz66
Laptop did not connect. Only wireless works.
Message 9 of 11
Guru
Well, it sounds like the ethernet hardware in the extender might have failed.  There's not much you can do about that (unless the extender is still covered by warranty).
But you might try unplugging the extender for a while (15 minutes or so), and then plugging it back in again.  Sometimes that can bring a "failed" port back to life.  A second reset might also be worth a try.
Message 10 of 11
mjortiz66
I replaced it.  Found a really inexpensive one...got it next day.  Gotta love Amazon.
Thanks for the info!
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 7630 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
