Ultrabikeman
Jun 29, 2024Follower
How to change a device connection speed from 5G to 2.4G
MR60 Mesh Router and MS60 Extender:
Can a connected device be assigned from 5G to 2.4G connection speed? My Amazon Echos all need to be assigned to 2.4. If so, how is this done?
You'd have to separate the bands to do so.
Can I create separate 2.4GHz and 5GHz SSIDs on my Nighthawk Mesh WiFi 6 products? - NETGEAR Support
otherwise its based on your devices own roaming protocols.
1 Reply
