TelecomPro
Sep 08, 2016Follower
How to disable dhcp on a WN2000RPTv3 Firmware Version: V1.0.1.4
How do you disable dhcp on a
- Hardware Version: WN2000RPTv3
- Firmware Version: V1.0.1.4
1 Reply
The WN2000RPTv3 is a range extender, so it doesn't have a DHCP server. It does, however, use DHCP to obtain an IP address for itself. If you want to assign a static IP address, then you can do it in Settings > WiFi Settings.
