zambrelune's avatar
Jan 26, 2025
Issue setting up my netgear extender (ac1750 ex6250v2) and my netgear nighthawk M2 mobile 4G routeur
Hello,
I have since 2 years a mobile mobile 4G LTE Mobile Routeur M2( MR2100) that works correctly but does not have a long range.
I have recently bought a netgear extender AC1750 Wifi Mesh Extender that I would like to use to extend the MR2100 4G LTE Mobile routeur when  at home.
It does not work.
The nighthawk  app just block
I was able to configure it manually, the wifi ID of the MR2100 is identified and setup seems to go ok .. .
I am able to connect to the extender site and tried various configuration ( with or without mesh using same or different WIFI network id.
The connection client PC (or phone) to  extender generally works ( even if sometimes it took few tries)
BUT : the connection between the extender or the router generally does not work ( it is in in grey and the corresponding led is off ).
Only once (by restarting both the extender and the router that I had put close to one another) they were able to connect together. But after 5 or 10minutes it went off.. and the connection was lost . I never repeated this very small success again.
I tried the extender with another modem ( my fiber box) and it works well with it. It just not do work for the MR2100 which is an issue because I bought it specifically for it ?
Apparently I tested to late to benefit from netgear technical support.
Do  I need to change some configuration on the MR2100?
Did I do something wrong (but the setup is quite straightforward and I do not see what I could have done wrong)
Any suggestion is welcome
Regards
  • plemans's avatar
    are you hardwiring the EX6250 into the M2 and setting the extender up in access point mode?
    thats what I'd do.
    the M2 is a mobile hotspot and the fcc limits its broadcast power significantly since it travels around. You might find that the extender provides plenty of coverage on its own.
      • plemans's avatar
        I hope it works well for you!
