PatCol63
Jan 24, 2018Aspirant
N300 (WN3000RPv3) WiFi Range Extender Client link keeps dropping
Hi I have a N300 range extender (WN3000RPv3) which I bought a couple of years ago and used successfully pretty much without interruption. On 15 January I changed broadband provider which also meant a change in router. In order to get the N300 extender to talk to the new router, I had to do a factory reset and then update the firmware. It took a while and I had to update it twice to get it to work. The unit is now working, but it intermittently drops the client link - when this happens, the client link light goes off completely and nothing can connect to the extender. Switching the extender off and on again fixes the problem, but it would be useful to know if there's a more permanent fix. The signal between router and extender is fine - quite strong. The router is a Technicolor TG588V v2. Any ideas appreciated.
- DarrenMSr. NETGEAR Moderator
Have you tried to adjust the wireless channel on your router?
https://kb.netgear.com/25182/Resolving-poor-5GHz-wireless-range-signal-from-my-NETGEAR-router
This article can be applied to a 2.4ghz network as well.
DarrenM
- PatCol63Aspirant
Thanks for your reply. The link between my router and extender is solid; it's the client end of the extender which is prone to drop. would changing the router channel have any effect on that?
Yes as the extender would be using that channel as well to broadcast the the clients.
DarrenM
