onedigit's avatar
onedigit
NETGEAR Trek N300 Problem
So, I recently ordered this travel router. I connect my ethernet cable to the Internet/DSL port, then I switch the connection to "Wired." I then see the Treks WiFi SSID and connect. Upon succesful connect, a webpage opens and the page says its assessing the router. Next thing that happens is this error message:
No Ethernet Cable Is Plugged into the Router Internet Port
And I don't know what to do. The cable is plugged in! Help,
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Have you tried to open a different web browser than the one that is giving a error when setting up the router.
      DarrenM
