K4955
Oct 15, 2021Aspirant
NETGEAR USB control Center-EX6200/AC1200
NETGEAR USB Control center app installed in my PC.does not show any printer
Model: EX6200|AC1200 Dual Band WiFi Range Extender
It won't. Once installed, forget the USB Control center.
Not knowing what you are doing, it is impossible to say much more than that.
Do you have a problem with the printer?
Does the printer show in Windows?
- K4955Aspirant
Do not have a problem with the printer, which is shared in Windows 10 64 bit, configured as a network printer using static IP address. The printer and scanner due to multi function is visible under basic Microsft Scan program as well as HP Scan & Capture, due to USB cable connected directl to PC. I can print and scan to the existing printer, but want to use the sanning function using NETGEAR Readyshare Printer utility.
Maybe this depends on the Netgear device you want to use.
But this bt is puzzling:
That is for a device connected to your EX6200. It isn't for things connected to your PC.
I assume that you have checked the relevant bits in the manual.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Look for the model number on the label on the device.
Begin with the Quick Start/Installation Guide.
Look for the sections in the manual Install the ReadySHARE Printer Utility and Use the Scan Feature of a Multifunction USB Printer.Is the Model: A6150WiFi USB Adapter listed in your footer involved in this in anyway? Or did you just click the first thing that popped up when you wrote your message?
- Gonzalez666Aspirant
I profoundly like your dedicated abilities as the post you distributed has some incredible data which is very valuable for me.
- K4955Aspirant
I have both R7900P and Ex6200/AC1200 and was successful in establishing connection with Printer with R7900P.
Does this mean that your problem is solved?
