mesber's avatar
mesber
Follower
Oct 17, 2017
NetGear WiFi Range Extender
I set up my wifi range extender and it works perfectly fine but my regular wifi is slow.  Is that normal?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Have you done speed tests with the extender plugged in and without it? if so what is the speed difference?
    DarrenM
