jamielasagna
Mar 04, 2021Aspirant
Netgear EX2700 extender connected via ethernet, but saying I'm not connected on the Netgear Homepage
Title is pretty self-explanatory, my PC is connected to the Extender via Ethernet, but whenever I attempt to go to the Extender's homepage, the website says that I am not connected to the Extender's WiFi network. I've checked to see if I am connected to any other networks and I am not. I can't connect the Extender to any other networks due to the inability to change networks on the homepage. Any help would be appreciated.
Are you able to access it using its ip address? NOT using the mywifiext . net
You can find its ip address in the routers attached devices page (or equivelent)
- jamielasagnaAspirant
Both 192.168.1.1 and 192.168.0.1 time out whenever I try and search them.
those are router ip addresses, not extender.
what router do you have?
if you open a command prompt on your computer, type ipconfig, the default ip address should be the address for the router.
