Tequila99's avatar
Tequila99
Netgear universal extender WN2000rpt v2 won't connect to my Nighthawk d7800
Hi,
I have a Nighthawk D7800 - AC2600 and a WN2000rptv2 extender.
No matter what I try, I cannot get the two to connect via the wps. I've tried using the wps button as well as the pin code in the router settings.
How can I get the wifi connection sorted?
    • Tequila99's avatar
      Tequila99
      WN2000rpt v2 isn't on the list as compatible with windows 10, is this true?
      • plemans's avatar
        The extender isn't connecting to windows 10. its connecting to the router and rebroadcasting it.
        You can set it up via the browser setup method and it should still work.
        Plus when that extender was manufactured (2012), windows 10 wasn't released. :) that's why there wouldn't be any compatibility listed.
