krick1's avatar
krick1
Nighthawk Range Extender App
I got the 1600 model range extender and couldn't even set it up. The app refused to connect/log the extender into the 5.2gHz band of my Bell Home Hub 300 router. Tried multiple times and repeatedly said the password is wrong, when I literally went back onto my actual SSIN so I could go into the band's wifi settings specifically to screenshot the share QR as it has the wifi password underneath it.
  • plemans's avatar
    Not clue what model extender you have as you didn't give a model number.
    You can try using the WPS method of setup.
    or you can set it up using the installation assistant.
    Here's a video of how to use the assistant.
    https://www.youtube.com/watch?v=yJVklshxBMk
    if you need to, To factory reset, push and hold the reset button for 7-15 seconds while powered on.
    i got this.. https://speedtest.vet/
