Drew061999
Apr 03, 2020Follower
Nighthawk x6 ac2200 tri-band wifi range extender
Hey guys. So my box was working fine but stopped working and now the box wont even turn on at all i tried reseting it and plugging it in different outlets still no turn on theres no lights no nothing how can i get this to work please and thank you.
1 Reply
There's zero lights on it when plugged in and the on/off switch pushed?
Not even a blip?
Then I'd see if you have a matching power supply to try.
Usually if you can't even get the lights at all, there's been some sort of hardware failure. Either of the power supply or the unit itself.
