James_London's avatar
Nov 18, 2024
Some sites unreachable
I can access sites like YouTube and LinkedIn but most other sites give “site unreachable” on Chrome & Safari. When I do a full reset it works for 1 day then goes back to same problem. Plus the sites that don’t work give a Unsecure Site sign in the browser address bar, even for standard reputable sites. Whitelisting sites does not work. Any advice?
  • plemans's avatar
    1. what router do you have?
    2. what modem/gateway is it connected to?
    3. what extender do you have (since you posted in the extenders section)?
    4. Firmware on the extender?
    5. What setup method did you use? WPS? The installation assistant? The app?
    • Hi Plemans,
      I have a modem/router from my ISP in France, it is an Orange Livebox 4 Fibre
      I have a Netgear EAX20 extender
      Firmware is the latest V1.0.1.64
      For set up I used an Ethernet cable between modem and extender and used the www.routerlogin.net site with admin login to set up through that site after needle reset on extender. I chose use as extender instead of as AP, as I want a WiFi link between the modem and extender, not an ethernet cable. What is strange is that it works fine for a day or 2 and then I get site unreachable. But is fine for LinkedIn or YouTube, I’m guessing because they use CDN or have different security settings from standard sites like Bloomberg.com
      I see other thread that mentions switch to static DNS and IP and/or roll back to earlier firmware version.
      Thanks for reaching out! James
      • plemans's avatar
        James_London wrote:
        Hi Plemans,
        For set up I used an Ethernet cable between modem and extender and used the www.routerlogin.net site with admin login to set up through that site after needle reset on extender. I chose use as extender instead of as AP, as I want a WiFi link between the modem and extender, not an ethernet cable.-----AP mode (access point mode) requires the modem/extender be hardwired together. If you want it wireless, it needs to be setup in extender mode. If you set it up in AP mode and its wireless, I'm surprised it even slightly works.   What is strange is that it works fine for a day or 2 and then I get site unreachable. But is fine for LinkedIn or YouTube, I’m guessing because they use CDN or have different security settings from standard sites like Bloomberg.com
