grogger
Oct 27, 2011Follower
WN2000RPT newbie questions
So I just bought a Netgear WN2000RPT to extend my wifi in my house. Here is the situation...I have a dlink DIR-615 wireless router downstairs and i have networked it to the WN2000RPT. I have the light for the extender powered on and the light for the extender connected to the PC. I have followed the installations guides but have a few probelms.
1. When I press the WPS button ((not sure if I need to) the light doesn't going on and never flashes.
2. I can't access the www.mywifiext.net webside.
Can someone please help me out.
Thanks
Thanks
1 Reply
- jmizoguchiVirtuoso
WPS will only work if main router support WPS.
use encryption that to connect to main router instead. setup guides has BOTH setups procedure2. I can't access the www.mywifiext.net webside.
http://support.netgear.com/app/answers/detail/a_id/14239
