justas
Jan 03, 2018Aspirant
WN3000RPv3
Hi, I have a N300WiFi Range extender, model WN3000RPv3, which is 18 months old. I have recently had a new router and stated from scratch with set up of the extender. Initially the extender worked perfectly however recently the extender keeps going to boot (amber light shows) we then loose the wifi signal. Sometimes it re-boots quickly but mostly very lengthy in time. Can anyone suggest what the problem is?
- DarrenMSr. NETGEAR Moderator
I would make sure you have the latest firmware on the extender also you may want to factory reset the extender by holding the reset button for 10+ seconds then setup the extender again.
DarrenM
- justasAspirant
Many thanks I will try that when it next plays up as for some reason after turning off power for a two minute period and tuning back on it is working ok.
