Orbi WiFi 7 RBE973
Reply
WN3500RP - how to allow device to device communication?
Sitka33
Follower
I am using a WN3500RP range extender and trying to connect a Skytrak golf launch monitor and my iPad. The Skytrak launch monitor requires device to device communication to be enabled to function so it can link to the app on my iPad. Documentation suggests that "guest mode" must be turned off so device to device communication is possible.
is this possible on the WN3500RP? The devices work on my router network but don't seem to link on the WN3500RP extender... So I'm guessing "guest mode" is on by default? Can it be turned off, and if so, how? I can't find any reference to such a setting in the WN3500RP documentation.
Model: WN3500RP|Universal Dual Band WiFi Extender
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: WN3500RP - how to allow device to device communication?
Hello Sitka33
No guest mode on the WN3500RP only if you are extending the guest network of your main routers.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3165 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
