MaxKizziar
Jan 25, 2023Aspirant
WiFi extenders
I would like to use two AC1200 Range Extenders in my home with my router. Is this possible? If so, can you pls provide guidance on configuring.
Is it possible? Yes.
Should you do so? Depends.
I usually recommend if users are needing more than 1 extender to move to a wireless mesh system like netgear orbi or MK nighthawk.
Reason why is standard extenders drop throughput 50%. This happens because they have to use the same chip to go router----extender and then extender-----device. And they can't do both at once. so they're going to take a speed hit. this gets even worse if you daisy chain the extenders (router----->extender------>extender)
they can work if they're setup in a star configuration
star: extender<-------router------->extender
But they can have issues when setup using a mesh setup as they can end up connected to each other.
so it gets more complicated.
Its why I usually recommend the move to a mesh system if needing more than 1 extender.
- MaxKizziarAspirant
Thanks much! Will examine this option.
