lorilone1
Mar 20, 2018Aspirant
cannot connect to wifi extender ex7300 - can't connect to this network
I had the entire house connected perfectly with 2 wifi extenders and router - all Netgear Products. Router: Nighthawk X6 R8000 - Extender N300 WiFi Range Extender and Extender Nighthawk X4 AC2200 Range Extender.
We recently lost power and I have been unable to get the second wifi extender to cooperate after more than a dozen times of trying everything. I finally get it hooked up and then final outcome is that I can't connect to this network. Please help, I have been dealing with this for days now and just need to have this work so I can hook up additional devices.
1 Reply
- jvasanth1984Virtuoso
Hi lorilone1,
Did you tried turning off all the devices and turn them on in sequence like Router, extender 1 and extender 2. How are your extenders connected to router, ie: both are connected to router or its like router->extender 1->extender 2?
