- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Boot loop after firmware upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
After doing a firmware upgrade within the DumaOS page the router is now stuck in a perpetual boot loop. Nothing on it works. Help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Boot loop after firmware upgrade
How wast he FW updated? With a wireless or wired PC? Wired is always preferred.
What browser did you use to do the upgrade? FF or Opera is preferred.
Try this and see if you can get the XR recovered:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
First try Windows 7/10 built in TFTP program.
@Raith13 wrote:After doing a firmware upgrade within the DumaOS page the router is now stuck in a perpetual boot loop. Nothing on it works. Help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I tried this. It gets through the "PUT" step, the power LED goes solid white and nothing else happens. I left it for 6 hours without anything happening. I then restarted the router only to be greeted with the same blinking white LED. I then tried the same process with an older version of firmware and got the same result.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recommend you contact NG support and see what they can do for you.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Open a support ticket here:
