ptigad's avatar
ptigad
Cisco Anyconnect VPN - WNDR3700 works - Nighthawk XR500 doesn't work
Hello,
I've tried searching through the discussions/faq's and can't seem to find a solution to my VPN issue.
I have a work laptop with Cisco Anyconnect VPN software installed and it can connect to work just fine if I use my old N600 wifi router.  However, my XR500 is blocking something and doesn't allow the laptop to connect.  I grabbed wireshark captures and can't seem to figure out why the newer XR500 won't work.
I've tried setting NAT to Open, disable/enable UPnP, enable ping on internet side, all to no avail.  I also just updated to the latest firmware, but it still has no effect.
Anyone have similar issues or know of a solution?
Thanks in advance
  • Hello, could you try disabling QoS from Anti-Bufferbloats' 3 line menu please and see if that resolves the issue?
    • ptigad's avatar
      ptigad
      I've got to wait until this weekend before putting the XR500 back into service and testing it out.  I'll let you know how it goes.
      • BanditMask's avatar
        BanditMask
        I had the same problem. I found that the Hybrid VPN was switched on with no config. I turned it off and also turned off all QOS and could connect.
    • bschollnick's avatar
      bschollnick
      I'm having the same issue with Cisco AnyConnect VPN not working with the XR500, and Firmware v2.3.2.56?
      I've connected Netgear, and they are looking into it, but it's strange that I can find quite a few threads regarding NetDuma OS not working nicely with Cisco AnyConnect...
      One observation in my case, Cisco AnyConnect (Macintosh) works fine.  Cisco AnyConnect (Windows 10-64bit) does not work.
      The Windows version reports:
      • Connection Attempt has failed (error in response data)
      • The AnyConnect Client service is not responding.  A VPN Connection Cannot be established.
      If I bypass the router, and go directly to the cable mode, AnyConnect Windows works fine.
      From this thread, we know this has been investigated at least as early as 2019-03-14?  Any chance that NetDuma has some better information or a more updated Firmware that Netgear hasn't released yet?
      • Netduma_Alex's avatar
        Netduma_Alex
        NetDuma Partner
        No sadly not. I imagine this issue has something to do with UPnP not facilitating the connection correctly. Maybe some manual port forwarding is required?
