ahettlin
Dec 11, 2018Aspirant
DNS Suffix
I had to replace my old router with DD-WRT because it was severely limiting my internet speed (by about 50%). I was debating between getting an XR500 or an X6S. I chose the XR500 because of what I read about DumaOS being such a great OS. The first thing I noticed when setting it up is that the software seems to be pretty lacking. Sure, it's pretty, but there are very few settings available. The one feature I really liked on my DD-WRT router is the ability to set the DNS Suffix so I can access the machines on my network by hostname. Does that feature exist and I just can't find it? If not, can it be implemented? It seems like a feature that should be standard. Thanks.
- Netduma-FraserNetDuma PartnerThat feature is not available as far as I am aware. Settings is developed by Netgear so that would be one for them to do. I'll pass on your request to their team.
- ahettlinAspirant
Ok. That makes sense. Thanks for passing it along. I suppose I'll have to figure out an alternative solution for now, or get a different router.
- Netduma-FraserNetDuma PartnerI'd suggest sticking with it for the QoS and Geo-Filter features, they will make a big difference to your gaming and general online experience.
