- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DNS
- Mark as New
- Bookmark
- Subscribe
- Permalink
DNS
Hello so when in command prompt when i ping the DNS 1.1.1.1 and 75.75.75.75, the results show in command prompt that 75.75.75.75 is faster by a few MS but in a benchmark shows 1.1.1.1 is faster but i feel like CMD is more reliable
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: DNS
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: DNS
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: DNS
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: DNS
router uses my ISP default DNS, thus when i input my DNS as my router, i will be using the ISP default DNS but what if i dont input the DNS as my Router what if i input as an ip that is not being assigned or my router is using for instance 192.168.1.60
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: DNS
also is using the router as a DNS server faster then just inputing 1.1.1.1 since my router wouldnt be a DNS server then ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: DNS
also meaning that it would be more beneficial to input my gateway as a DNS instead of just inputing 75.75.75.75 correct ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: DNS
Since NG doen't allow DNS Proxy or Relay to be disabled on there routers, you can input ON the router ISP DNS or custom DNS. Some other router Mfrs allow to disable DNS Relay or Proxy thus sometimes having better router performance by having the router access ISP or Custome DNS and passing this thru to connected clients. There maybe some neglegable performance by using DNS Proxy or Relay. NG seems to handle this well regardless. I use custome DNS values on the router and let the clients get auto DNS values from the router. No need to input anything on the clients.
So use either ISP or custome DNS addresses, and let the router handle things. Works well for what it does.
