× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Does "Region Selection" matter?
Hello Netgear Family!
I just had a quick question. Under "Settings > Setup > Wireless Setup", does the "Region Selection" make a difference to my connection? If I set this to Europe, will I get connected to servers in Europe? I live in India, so should I set this to India? and will this effect anything? It's not a pressing matter, but I was just curious.
Thank you! 🙂
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 4
Accepted Solutions
Guru
Re: Does "Region Selection" matter?
WiFi channels are regulated in each region.  For instance, Japan allows WiFi channel 14 for 802.11b - other countries don't allow it at all.  In addition to the legal WiFi channel list, the WiFi power limit also varies by region - and sometimes those limits are set differently for specific WiFi channels.
You should set the region correctly - ensuring that your equipment is compliant with the laws in your particular country.
Message 2 of 4
All Replies
Guru
Message 2 of 4
Hello @StephenB,
Thank you so much for the prompt response.
As per your advice, I have set the router region to my country. I was not aware of the legal implications of Region Selection. Very interesting.
Thanks
Message 3 of 4
Netduma_Alex
NetDuma Partner
Yeah in some countries they reserve certain channels for military use, and I know that for example the EU doesn't allow you to use 5GHz WiFi for any outdoor appliance.
Message 4 of 4
Discussion stats
  • 3 replies
  • 9431 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
