Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Dymo printer not detected
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-03-09
12:45 PM
2018-03-09
12:45 PM
I currently have a Router XR500 and after connecting the printer to the USB port is not seen in my macbook pro computers, does anyone know what to do?. Previously I had R9000 and everything was ok.
Please help
Message 1 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-03-09
01:08 PM
2018-03-09
01:08 PM
Re: Dymo printer not detected
Hi szulerus, if you go to Settings > USB Storage > USB Settings do you see your printer listed?
Message 2 of 6
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-03-09
01:09 PM
2018-03-09
01:09 PM
no, unfortunately no
Model: XR500| Nighthawk Pro Gaming Router
Message 3 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-03-09
01:14 PM
2018-03-09
01:14 PM
That sounds like the cause, is the option 'Enable any USB Device connected to the USB port' set to yes? If so try a different USB port on the router & if possible try a different USB cable to connect them.
Message 4 of 6
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-03-09
01:18 PM
2018-03-09
01:18 PM
any USB option its enabled. I tried on both USB ports without any results. I have similiar printer (brother) and it is detectable on my computer.
previously i had router r9000 and without any problems Dymo was working.
I tried to connect directly dymo to my computer via usb and it is working flawlesly.
looks like router wont work with this priner
Message 5 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-03-09
01:20 PM
2018-03-09
01:20 PM
Do you have an alternate printer you're able to try? As the Settings & hardware is done by Netgear I would recommend contacting their 24/7 support helpline in order to get it resolved quickly. If you go here and login you should get a number to call: http://support.netgear.com/
Message 6 of 6
Announcements
