Reply
Help! Xbox not connecting to friends party
Rutdawg
I cannot connect to my friends party with my Netgear XR500. I have my Xbox on energy Saving mode and my router is updated.
Netgear needs to fix this! Anyone have any suggestions?
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 26
Netduma_Alex
NetDuma Partner
Re: Help! Xbox not connecting to friends party
Are you using the Geo-Filter? If so:
  • Set Geo-Filter to Spectating Mode
  • Turn off Auto Ping Host
  • Join the party with your friends
  • Click on your friends on the map, name them and press ALLOW
Now when you use the Geo-Filter, they should be allowed through.
Message 2 of 26
Rutdawg
Is there any other options? I can't even connect to them after disconnecting geo filter and auto ping. So frustrating.
Message 3 of 26
Netduma-Fraser
NetDuma Partner
If you can't connect to them with the Geo-Filter disabled then this points to a potential NAT issue. What is your NAT Type shown in the console network settings?
Message 4 of 26
Rutdawg
NAT type is open on xbox
Message 5 of 26
Rutdawg
My NAT type is open on xbox.
Message 6 of 26
Rutdawg
I actually have another router that works fine so I know the router is having the issue. Can't believe I spend almost 300 on a plastic paper weight.
Message 7 of 26
Netduma-Fraser
NetDuma Partner
Could you provide a screenshot of the entire Geo-Filter page please when you're trying to add this person to a party chat (use imgur). There should be no reason this doesn't work if the Geo-Filter is properly disabled and NAT Type is open.
Message 8 of 26
Rutdawg
How do I fully disable geo filter? I had to add Xbox to have the geo filter to spectate
Message 9 of 26
Netduma-Fraser
NetDuma Partner
So it was never added in the first place when you encountered the issue? Just remove any devices from the Geo-Filter.
Message 10 of 26
Rutdawg
It has been off the geo filter untill I added it earlier today. The problem is still there either way.
Message 11 of 26
Rutdawg
I can't believe I spend 300$ on a huge headache. I'll send a picture of geo map in 30
Message 12 of 26
Netduma-Fraser
NetDuma Partner
What is your physical setup? E.g. ISP router/modem > XR500 How is the ISP router setup? What message do you get when you're unable to join?
Message 13 of 26
Rutdawg
It's the router hooked up to Ethernet (fiber optic internet). When I try and join party it says router settings are preventing you from joining
Message 14 of 26
Rutdawg
Message 15 of 26
Rutdawg
Your network settings are blocking party chat[0x807A1007]
Message 16 of 26
Rutdawg
Nothing pops op on the map because I can't even connect to them. All I see is the blank geo filter.
Model: A6200|802.11ac Dual Band WiFi USB Adapter
Message 17 of 26
Netduma-Fraser
NetDuma Partner
The XR500 would have to be connected to a router/modem, do you know what model it is? The Geo-Filter is disabled that's fine which is why it is blank, just meant the Xbox error so thanks for that. Can you put the Xbox IP address in the XR500 DMZ in WAN Settings please and see if that resolves it.
Message 18 of 26
Rutdawg
it's just the XR500 router. Okay I'm trying
Message 19 of 26
Rutdawg
I put the up address in and still can't connect.
Thanks for trying to help me.
Message 20 of 26
Rutdawg
I'm absolutely never spending money on Netgear again. This product has done nothing but help give me a hernia.
Message 21 of 26
Netduma-Fraser
NetDuma Partner
So you have an ethernet cable that just comes out of the wall then, do you have an ONT? Can you try it directly connected to the wall and see if it occurs please.
Message 22 of 26
Rutdawg
We do have an ont
Message 23 of 26
Rutdawg
I've seen many others with this issue. Netgear or Xbox needs to address this because I spent a lot of money on this thing just to play xbox and it doesn't work. If I wanted a regular router I wouldn't spend $300 on a specific gaming router!!! Might as well say doesn't connect to friends on the box because that's what I bought! Unbelievable. I just bought a new linksys router so I'll throw this waste of space away.
Message 24 of 26
Netduma_Alex
NetDuma Partner
I believe that if you're using an ONT you might need to put something into the VLAN settings.
Message 25 of 26
Discussion stats
  • 25 replies
  • 2951 views
  • 1 kudo
  • 3 in conversation
Announcements
